I am building/designing a beachtri for the 2023 season, from parts I have collected through the years. The main components are: Center hull from an 70´s Sailcraft UK Tornado, a Marstrom Tornado mast, floats from a Nacra beachcat, a Nacra 18sqm main, a 5.35sqm Tornado jib. I built 3.2 m beams for a catamaran project a few years ago, but decided to use them for this larger project instead, by lengthening and reinforcing them. The other beam tubes are rests from a almost ready built small hydrofoil, that is due to sail this summer.
The main beam dolphin striker is of conventional type, like on the Tornado or any other beach catamaran. In an attempt to exclude a conventinal rear waterstay in line with the rear beam to minimize work on the Tornado hull, I got the idea of running a diagonal Dyneema DM20 waterstay from the rear beam ends, to the main beam striker band(40x3mm stainless) attached on each hull side(red).
To counteract the rear going force, another DM20 stay could then be attached from striker band to the ama forestay chainplate if needed(blue).
The forces are not large, but the rear beam could benefit from a little additional help, as I want want to add some security. Of course you loose ca 0.7 of the force due to the close to 45 degree angle.
I can not foresee all forces involved in this arrangement, nor the illeffects, so any thoughts on if this could work for the rear beam as suboptimal waterstays, would be greatly appreciated.
Hope the MSPaint-sketch is understandable.
Cheers
Lars
